Bravo to Arneson Conversions
Who's done it and what performance changes did you get?
I am doing it now. I have 3 x 540 Bullgogs with Bravos on my 50' Hustler 83MPH is my top speed. with just the ASD-8's the speed should be plus 10MPH. I am also doing the motors to 700EFI's so my new speed should be just over 105MPH unless I end up with more HP than planned.
I am having Hustler fill my holes and mount the new drives. |
I'd be curious of the performance gains on a straight bottom 38' cig are. 10mph on a big boat like that is pretty impressive.
How much does the bravo conversion asd actually go for$$$? There is virtually zero used asd's out there but I have contemplated this for my old sled as well. Pretty much the only way for me to get a rooster tail and low slip numbers LOL.. Also, what are the dockside manners of an asd like when compared to a bravo? |
Originally Posted by baywatch
(Post 3249355)
About a year ago, it was $23,000 per side for the ASD7M. That is not installed nor props. Also, you will need an external water inlet. It's going to cost over $50,000. My guess would be around $55,000. Pocket Change, right?:lolhit:
Wonder how long it takes to dial them in???
I'm sure it's a lot of work. For my 1994 CIgarette Top Gun application, I think I would have to pull one of the motors to install an external water inlet for my water pumps. I may be wrong. I don't think installing the drives would be too hard, as the ASD7M is suppose to fit over your existing bravo 1 holes. I talked to an individual who installs these Anresons, he charges around $4000-$4500 to install the Arnesons on my Cigarette. He did not say anything about the water inlet. I would love to have some Arnesons myself, but I don't have that kind of money to spend.
Originally Posted by UrbanDisturbance
(Post 3249616)
(Post 3249686)
LOL. My pockets need to get a bit deeper before I can take that plunge....
I guess it depends on dollars to return.
How much money to make enough extra horsepower to get an extra 10mph on a 70+ mph 35-45ft boat and how long would the bravos last after adding that much power and how much to beef up bravos to handle that extra power? Id say when all is said and done you would probably pretty close to the same amount either way. |
