-   -   B1 water pickup ?? (https://www.offshoreonly.com/forums/drives-lower-units/245128-b1-water-pickup.html)
boatntrkr 01-06-2011 10:21 AM
B1 water pickup ??
I tried looking back a few pages but didnt see anything about this, so I'll ask.
Is there anyway bypass the water pickup/impeller on the lower unit and just put a hull mounted water pickup like the bigger engines have?
Obviously i'd have to drill a hole and use a water pickup fitting, but other then that, are there any special pumps or equipment needed?
JaayTeee 01-06-2011 11:04 AM
Bravo's dont have an impeller in the lower unit,
they have an engine mounted sea pump.
Alpha's have an impeller in the lower unit though.
You can add a hull pickup for a bravo application.
You'll still want to let the water circulate through the
drive though, for drive cooling purposes.
boatntrkr 01-06-2011 11:11 AM
learn something new everyday....ive never messed with bravos..trying to learn as much as possible before I do get one though...thanks :coolcowboy:
