-   -   o-ring lube (https://www.offshoreonly.com/forums/drives-lower-units/245657-o-ring-lube.html)
pino56 01-14-2011 08:58 AM
o-ring lube
about to assemble bravo 1 upper & lower housings together. i have a seloc repair manual telling me to coat new o-rings with 3-M adhesive. im a bit skeptical so i am looking for some advice on what is perferred. thanks.
mike tkach 01-14-2011 09:41 AM
i put some oil on the oring and put it on the ring bore
FogduckerIII 01-14-2011 10:58 AM
IMO the two "gaskets" to worry about are the water intake port and the gear oil resorvoir port, I put a small "dab" of bellows adhesive in the ring bore just to hold the gaskets in place and a light coat of gear oil or similar on the mating surface. There is nothing worse then getting the upper and lower together and finding out a gasket has fallen out or not seated correctly....
Also, double check the shift linkage has engaged before tightening everything down....:coolcowboy:
US1 Fountain 01-14-2011 11:06 AM
I prefer oil on o-rings. Don't have to worry about the adhesive effecting the o-rings abilty to seal.
Clustergear 01-14-2011 05:23 PM
Merc. Special Lube 101
roush42 01-14-2011 06:30 PM
silglyde works well.
Mr Gadgets 01-15-2011 09:15 AM
I second what Fogducker said.. just enough to hold them in place.
pino56 01-17-2011 09:21 AM
Thank you all for your responses
