-   -   3.0 sportmaster lower info (https://www.offshoreonly.com/forums/drives-lower-units/246924-3-0-sportmaster-lower-info.html)
Baja170 04-30-2016 10:03 AM
6 Attachment(s)
It has been done before but you can also put the overflow bottles under the motor cowl. Here are some pics. Same reservoir as my 500EFI in my Cougar. I would guess any I/O Mercruiser. This worked, the guy has three 300x's on a pretty big boat that surfaces on some really rough water and was drawing water in the lower on cooldown. Yea he is known to put metal to wood quite a bit or be parked at a watering hole.
steelborn 08-22-2016 08:53 PM
Where Wayne Taylor's 4-seal carrier can be bought?
I'm having trouble finding it...
mosport1 08-22-2016 08:59 PM
http://www.wickedpowerboats.com/parts.html
I believe the Taylors have closed up shop.
steelborn 08-22-2016 09:43 PM
Great, thank you Mosport1
Ca.Viking 04-12-2023 10:08 PM
Anyone looking for 20" 1.62 fats shaft L & R?
Originally Posted by HIGH LIFE (Post 3314927)
Lakeland vent kits worked for me. Do you have hardened steel drive & prop shafts or SS ? Do you have 2 piece drine shafts ? Size of mids, 20" or 25" ? By the way like your PORTA LIFT !!! "HIGH LIFE"
I have drive shafts extensions and couplers for sale. Will soon have fat shaft 1.62 L and R for sale also. 626 825 4123
