-   -   Bravo drives gear ratio change (https://www.offshoreonly.com/forums/drives-lower-units/246948-bravo-drives-gear-ratio-change.html)
ktm2212 02-03-2011 03:58 PM
I have 38' T/S Cig Top Gun with Bravo I drives. They currently are 1:36 ratio with 26 pitch Bravo props pushing just under 600hp. Top speed is 87mph but 84mph all day. They have given me no problems whatsoever but I know it's a matter of time so I'm gentle with them. I am giving serious consideration on the XR upgrade this winter (which is all the budget will allow). All of the local guys tell me to switch to 1:50 gear ratio for better performance. Will this give me any difference in top speed of the boat or is it just mid-range? I feel the current set up has plenty of punch in the middle. Am I correct in that the 1:36 ratio is a little easier on the drives? Just looking for some feedback..... Thanks
JMS322 02-03-2011 05:24 PM
I switched from 1.36 to 1.5 on my 38 Powerplay. Picked up 4 mph and there is probably more to be had. It did cause a number of other issues when I made the change. I don't have Bravo's though, I have B-max's. I did run in to some issues.
The gear change drastically increased leverage and I had to add spacers to drop the drives down another 1" to get the boat on plane. I tried the drives 1 1/2" deeper, but raised them back up 1/2". Sure I could have purchased some 5 blade props, but I was worried about breaking gears due to the extra bite. I wanted to stay with 4 blades.
I went from 26 Bravo 1's and am currently turning 32's but also have a set of 34's. I rarely run my boat WOT, so top speed is not an ultimate concern. I made the switch when I was freshening the drive since it needed new gears anyway.
I guess what I'm saying is be prepared to do some tweaking if your prop shaft depth is fairly high and have a good assortment of props to test.
I was told just the opposite as far as the 1.5 gear ratio being easier on the drives.
JaayTeee 02-03-2011 05:40 PM
XR's arent bullet proof.
A friend of mine has a 02' 38 TS TG w/500EFI's and XR's
In 09' we put a upper gear set in one side because
the teeth were falling apart, last year the opposite side
broke a tooth off and junked a whole upper out.
And then there's my experiences with them on my own boat, but it's depressing, so I'll spare you.;)
Also XR's consume a little bit more power than the standard helical gears do, so be prepared for a slight speed loss.
If you're really looking for a better mousetrap look at a IMCO
SCX, or the BMAX ( they're under new ownership)
Quinlan 02-03-2011 07:48 PM
What he said!
JasonSmith 02-03-2011 09:54 PM
John, how did changing the gear ratio increase leverage? I'm lost on that one buddy.
JMS322 02-03-2011 10:16 PM
Probably a bad choice of words. Torque at the prop would change. ie: an engine producing 1000 ftlbs of torque would have 1360 ftlbs at the prop with 1.36 gears and 1500 ftlbs with 1.5 gears. Maybe my logic is off or I'm missing something. I know you spent a lot of time on the setup on your 29 Outlaw. See this thread about my gear change experience. http://www.offshoreonly.com/forums/d...ng-advise.html
JasonSmith 02-03-2011 10:37 PM
It's all smoke & mirrors & magic buttons to me, but I see what you're theorizing.:drink:
E Dock DD 02-03-2011 11:13 PM
I would think that keeping the gears closer to 1:1 would be easier on the gears and turning more rpm at the prop would also be easier on the drive (less torque per revolution on the propshaft and lower part of the drive). I suspect the speed difference could be due to less slip with the larger pitch prop at hight speeds. These are just my basic engineering thoughts. There are always trade offs.
ktm2212 02-03-2011 11:24 PM
Excellent feed back. You have me a bit concerned because my drive height is a bit on the high side. I have had others recommend the 5 blade props but I would tend to agree that the four blades would be easier on the drives.
I know XR's are not bullet proof but consider I was told the Bravo I's wouldn't last a season, so I still consider it an upgrade over my current set up.
I would hate to lose any top end with the ratio change...which is my basic question
JMS322 02-04-2011 07:59 AM
As far as prop shaft depth. Mine with NO spacers is 2" below the transom. I am currently at 3 1/2", but have also tried 2 1/2" and 4". It is amazing the difference that 1/2" makes.
How you treat the sticks is going to have a BIG effect on the life of the gears and drives.
I've heard the Bravos have less drag and will be the fastest. You will most likely lose MPH with the XR's, IMCO's and B-Max's, but you will gain strength and reliability.
JMS322 02-04-2011 08:44 AM
Is my theory flawed ? At the same prop depth with the gear change there was NO way to get the boat on plane with the same props.
Your welcome to come over sometime and use some of the smoke & mirrors & magic buttons on my PP. Sometimes things on paper don't make sense and there is no substitute or replacement for trial and error. Otherwise we would all get the setup right the first time with a few calculation off paper.
JasonSmith 02-04-2011 09:47 AM
10-4 on that!
JaayTeee 02-04-2011 11:20 AM
Originally Posted by Quinlan (Post 3315485)
What he said!
Spoken from someone else who knows.....someone
who broke 2 XR's in one weekend:eek:
Also on at TS TG.
Putting XR's on it is a waste of $$$, take that $$$ and set
it aside for good drives.
chaparral2300 02-04-2011 02:05 PM
wow mike, now that is feed back in record time chapie.
Quinlan 02-04-2011 03:40 PM
Also on at TS TG.
What was great was PBB rebuild and delivered 1st one to me at 2AM!! FRI morn to make fun run
2nd was rebuild Fri afternoon after it went DURING fun run!
Then can you say BABIED it rest of the Shootout.
JUNK!!
