bravo 2 gearcase???????
my cruiser needs a new lower unit housing for the bravo 2. its a 1993 7.4 carb engine. i found a complete drive from a diesel bravo 2.....will i be able to swap my gears into that case upper/lower?
the owner said it was a 2.0 drive ratio. i just wanna be sure that case will work for my internals. thanks everyone! |
The drive you found is a 1993 or the one you have? Need more info. If both are after 1990 you should be fine.
my bravo 2 is a 1993 that has deteriorated, the new upper and lower case i bought came from a diesel bravo 2 from a 2000 model boat.
i called a marina and they said that my internaks should swap over no problem. whatcha think? |
| All times are GMT -5. The time now is 11:46 AM. |
