Skeg replacement
I have a broken skeg on one of my outdives, It is the second time it broke, I bought the boat after it was repaired once. The second skeg is worn pretty good.
My question is did anyone try the stainless bolt on rather then pulling the drive and having them welded. Is there any down side to the stainless ? |
Originally Posted by Scarab29
(Post 3322769)
You can use the bolt on ones. They can scrub a little bit of speed off though.. Also you must make sure you have an adequate amount of skeg left to mount the fasteners in. If not you will need to either weld a new skeg on again or replace the case.. Also the SS can be a little rougher on the case if you should hit something. If you do it may damage the case even worse requiring more than a skeg..
Hope it helps.. :) BTW, If you are in the Poconos, you probably are not to far from me at all.. :) Jamie / Lakeside Restorations :) |
| All times are GMT -5. The time now is 08:27 AM. |
