Coupler/Spline Lube >
Coupler/Spline Lube
Coupler/Spline Lube
Old 03-20-2011 | 07:27 AM
Default Coupler/Spline Lube
I'll be pulling my drive soon to check alignment and gimbal bearing and U-joints and grease everything that can be greased but I was wondering if anti-seize might be a better choice than grease for the drive spline? I'll be filling it up with Quicksilver High Performance Gear Lube.
thirdchildhood is offline
Old 03-20-2011 | 12:09 PM
Use Merc Spline grease. It is some real tacky grease. I would not use anti-seize.
Griff is offline
Old 03-20-2011 | 12:21 PM
OK. You know I was thinking after I posted this that I think there is a zerk fitting on the coupler. I will use my marine grease on that and the gimbal bearing and u-joints if they have zerks. Thanks.
Old 03-20-2011 | 12:47 PM
Ditto on what Griff posted , and dont even think about that anti - seize
Old 03-20-2011 | 03:35 PM
OK.
Old 03-20-2011 | 04:04 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Spline grease for the coupler splines, U-joint/gimble grease for those 2 items.
Different requirements= different grease properties. Merc has that figured out.
US1 Fountain is offline
Old 03-20-2011 | 08:06 PM
The spline grease works well, I use the Amsoil Marine Grease
jeffswav is offline
Old 03-20-2011 | 08:23 PM
OK, is spline grease really needed or can I use the marine grease. The drive will be off at least every two years to check. I don't think it'll seize up. I was gonna do this next week weather permitting and the marine grease is already here.
Old 03-20-2011 | 08:46 PM
The grease is not really to keep the drive from seizing in. It is to keep the coupler teeth from wearing out.
I use Lucas Red & Tacky grease when greasing the zerts. Its sticky like the Merc spine grease, but I can use it on my trailer bearings and gimbal as well.
Griff is offline
Old 03-20-2011 | 10:42 PM
Regular marine grease will not hold up well. As was said before the spline grease is better. I use the Amsoil Marine Grease on the splines, gimble, wheel bearings, ect.... Its pure synthetic and simlar consitancy to the spline grease.
jeffswav is offline
