-   -   water leaking in engine compartment thru trs drives (https://www.offshoreonly.com/forums/drives-lower-units/250667-water-leaking-engine-compartment-thru-trs-drives.html)
mookster 04-03-2011 01:48 PM
i have 2x 330hp with borg warner trans and trs drives
i have water coming in thru the drives mounted to the transom
how hard is it to replace these seals?
will i need an engine hoist?
what are the steps to replace these? do i have to completely remove the trans?
thanks
mookster 04-03-2011 07:52 PM
anyone
bustedbrick 04-03-2011 08:03 PM
Where exactly is it coming through? between the gimbal and the transom? or from where the tranny plugs into the back side of the gimbal?
mookster 04-03-2011 08:17 PM
the gimbal and the transom. they have one of the drives on the outside of the boat matted up to the transom with silicon everywhere
picklenjim 04-03-2011 09:00 PM
You'll have to pull everything to fix that. Engine, transmission and entire gimble assembly. $40 gasket. Part #10 in this link.
http://www.perfprotech.com/store/ass....aspx#assembly
copperkettle1 04-04-2011 05:04 PM
you could try 2snug up the transom assy nuts and bolts. but be careful you could crack the inner transom plate. also watch the transom if its soft you will see itcollapsing or oozing water
mookster 04-04-2011 05:48 PM
dont mean to sound stupid but can i prop the motors up somehow ( block) and unbolt and take the tranny out and gimbel and fix it that way since i dont have acess to a hoist??
picklenjim 04-04-2011 08:47 PM
It can be done but isn't easy. It would be especially hard on a twin engine setup. I did it once on my single engine. The transmission would be left in with the engine. You have to support the engine and trans together at the transmission end. I held it up with a sling. Then remove the 8 nuts that hold the gimble assembly on. A couple of them are hard as hell to get to. It's a real pain in the a$$. Much easier to pull the engine and trans. Can't you rent a hoist somewhere ? Know anyone with a back hoe ?
fireboatpilot 04-05-2011 05:44 PM
Friggin cork gaskets. I mean could they produce a chincier part or what? Plan on replacing the gimble studs while your at it. If I remember correctly, the bottom 2 are bolts and nuts? I almost sunk my Scarab because of those gaskets. Also if they've been leaking for awhile, be sure to check the moisture content of the transom around the lower gimble area. I would guess there's some rot or at least some wet wood. Good luck, pretty big job.
picklenjim 04-05-2011 07:41 PM
Originally Posted by fireboatpilot (Post 3369245)
Friggin cork gaskets. I mean could they produce a chincier part or what? Plan on replacing the gimble studs while your at it. If I remember correctly, the bottom 2 are bolts and nuts? .
Nope. Their all studs with nuts on them. 8 of'm.
fireboatpilot 04-05-2011 08:22 PM
My TRS drives where 1978 so maybe they changed. I know the 2 bottom ones where caraige bolts that went in from the outside, the rest where studs. Doesn't really matter though, your right, to do it right the engines should come out.
