Originally Posted by Underdog88
(Post 3369346)
I drained both of mine thru a paint strainer and got nothing. Fine stuff on drain plug mags. but one came nice clean and green and the other was black. I'm a bit worried too.
Originally Posted by Griff
(Post 3369622)
Mine are the same way. Left hand rotation drive is pretty dark.
Interesting observations on darker oil in LH drives. Darker usually means hotter.
Now, it's common knowledge that Bravos can turn either way because they have symmetrical gear patterns but that necessarily doesn't mean that the oil is flowing properly turning opposite directions...could there be less cooling (foaming, etc.) when turning LH versus RH? |
Originally Posted by CigDaze
(Post 3369734)
(Post 3369622)
Originally Posted by BDiggity
(Post 3369433)
Could a bad bellow allow water in the bilge as well as the drive? Be nice if i could fix two issues at once.
(Post 3369823)
Hey Scott, so this will probably be a dumb question but is the rotation based on looking at the drive from behind or from the front? It was my starboard drive that was darker, & i assumed i was turning the props out, but i will verify. The port drive was nice & green.
(Post 3369906)
Looking at the props from the rear. LH is the one spinning counter clockwise.
| All times are GMT -5. The time now is 08:58 AM. |
