Originally Posted by waconda
(Post 3409114)
Well, for one thing you aren't looking at the correct product. The marine gear lube isnt' even listed on NeoOil's website. Amsoil is not just as good as Neo drive oil that we designed and we guarantee our oil for 75 to 100 hours depending on application, so by the time you change your amsoil every 8 to 10 hours you have spent more money than buying the NeoOil 75-90MRHD oil.
Originally Posted by 07DominatorSS
(Post 3409582)
Really? What makes you say that?
(Post 3409586)
Also, 8-10 hours on AMSOIL. I've run it for full seasons, 55-65 hours, and my tests still come back just fine. So....now what? Show me a data sheet on this so called Neo Oil. Would love to know more about and why its expensive as can be! I love comparing products.
(Post 3409788)
Really are you serious you think that a motorcycle oil is going to hold up to an out drive for more then a few hours.
(Post 3409788)
And what exactly do these "non-stock" boats need? Whats the magical potion? |
(Post 3409822)
Considering this is what Teague has run in his 6's for about 5 years now, in racing conditions and has seen literally zero wear, yeah, I do believe it will work just fine. And I'll put my AMSOIL up against anything you can bring!
(Post 3409822)
And what exactly do these "non-stock" boats need? Whats the magical potion? Heat is a bravo drives worst enemy IMO so by reducing it which is exactly what this oil has done for me, I have increased my drive longevity. Different strokes for different folks bro. If you like your amsoil, run it. We used to run it in our trucking company for years and saw lower trans and drive temps. On the other side of that coin is NEO oil and its blend has been doing very well in bravo based boats, mine included. |
[QUOTE=minxguy;3408248]
(Post 3371320)
Any motor oil is GL-1 rated. Look at any japanese motorcycle, common sump for engine, tranny, and clutch.
Amsoil didn't reinvent the wheel here by claiming GL-1 with their engine oil. The Japanese motorcycles have been using common sumps since they were made, way before Amsoil was even around. Motor oil will last in a gear box, but you can't use your typical high shear aotomotive polymer to blend it. You need a polymer that is typical of a gear lube, unless the motor oil is blended from base stocks with no polymer. Ken How is any motor oil GL-1 rated? i.e. the following.... http://www.mobil.com/USA-English/Lub...ycle_Oils.aspx This the Mobil 1 V-twin oil, which is very good, but even this data sheet doesn't claim a GL-1 rating. They actually state "These products will help provide excellent performance in motorcycle engines that are designed with a common engine/transmission lubrication system or where the engine lubrication system is separate from the transmission system. In the case of the latter, follow the manufacturer's recommendation for the type of fluid to be used in the transmission." So.... |
(Post 3409822)
Originally Posted by Strip Poker 388
(Post 3409831)
Your saying motor oil and gear oil is the same then
http://www.amsoil.com/storefront/mcf.aspx |
| All times are GMT -5. The time now is 12:37 PM. |
