Originally Posted by VolaticusNavis
(Post 3389988)
Sorry OP again.
Uncle dave im trying to PM you but your inbox is too full. UD |
Originally Posted by Rik
(Post 3388459)
Doing one right now... The drive will fit no problem
Sorry for the hi-jack, althought it's kinda related.....:drink: Hey Rik, I might be calling you later today to talk about ASD-6 gear lube replacement/type!!! Just waiting on a call back!!!!:eek: I talked to Cosker about the lube changes, he said it's a piece of cake!:drink: Thanks, Dean |
Originally Posted by Dean Ferry
(Post 3390145)
OP,
Sorry for the hi-jack, althought it's kinda related.....:drink: Hey Rik, I might be calling you later today to talk about ASD-6 gear lube replacement/type!!! Just waiting on a call back!!!!:eek: I talked to Cosker about the lube changes, he said it's a piece of cake!:drink: Thanks, Dean So.. Just drain the oil in the two cavities and then fill both from the bottom until the oil comes out the (second upper fill hole) and put the plug in.. Merc Hi Perf gear oil in both cavities is good. I have not found any difference between any of the drive oils with regards to Arnesons so use any oil you prefer. |
| All times are GMT -5. The time now is 11:49 AM. |
