-   -   TRS Gimbal rebuild (https://www.offshoreonly.com/forums/drives-lower-units/252172-trs-gimbal-rebuild.html)
GoFastSonic 04-25-2011 11:15 AM
TRS Gimbal rebuild
Ok its time to get the old race boat ready for another year of battle in OPA. Last season we had a gimbal the was pretty loose on the top and bottom pins. My question is how do we repair? What s the easiest way on the boat or remove gimbals from transom? Its been about 10 years since they were off and I am kinda afraid of what we may find. ANy help would be great and yes I know TRS is old stuff and I KNOW we should just put bravo's on it or a set of Konrads but $$$$$ dont grow on trees in this part of Jersey and were just out to have fun.
Mike O
531 WHOZ YOUR DADDY
P.S May have open spot for some races this year for Nav or maybe driver if interested PM me please.
picklenjim 04-25-2011 03:33 PM
I would just leave it on the boat. It would be a good holding fixture while your beating on it. You will need an acess kit to remove the steering arm easier though it can be done with out it. Really should have a manual if your going to attempt this. Mercruiser TR/TRS service manual #5.
http://cgi.ebay.com/ebaymotors/Mercr...ssoriesQ5fGear
GoFastSonic 04-25-2011 07:01 PM
no internal steering so that should make it easier?
picklenjim 04-26-2011 12:07 AM
Even though you may have external steering you still have to have the steering arm inside. Theres a nut on the top end of the swivel shaft which tightens against the steering arm to lift the gimble ring to aquire the correct clearence between the top of the gimble ring and the gimble housing. Then the steering arm tightens down on the swivel shaft. Clearence is .005"-.007" between the washer thats in between there and the gimble housing.
Access plug kit 22-88847A1
GoFastSonic 04-26-2011 05:46 AM
One gimbal already has these plugs on it?
DareDevil 04-26-2011 08:27 AM
well my dear frined MIke ...i wont say anything !!!!:lolhit:
picklenjim 04-26-2011 03:57 PM
Some one must have been into it before.
GoFastSonic 04-26-2011 07:35 PM
well measured the up and down play according to the merc book. They say it should be between .010 and .020 and mine is .020 - .021 so we gonna let it ride. They are no looser then the spare ones we have now.
ChineWalker 05-30-2011 12:43 PM
Quick question and not to thread jack; how many hours "under normal operating conditions" should the gimbal assembly be good for before tear down and rebuild? Happy Memorial Day!
