-   -   drive oil leaking between #5 upper and lower case. (https://www.offshoreonly.com/forums/drives-lower-units/253033-drive-oil-leaking-between-5-upper-lower-case.html)
bigfarmer 05-06-2011 08:35 PM
Has anyone ever have drive oil leak between the upper and lower housing on #5 drives...? pulled the boat out of storage and on BOTH drives there is oil that has been seeping between the cases. I know these are sealed with O-rings and probably need replacing but what would have caused this?....
DareDevil 05-07-2011 09:43 AM
unproper installing and age !
if you replace them, use perfect seal on them ...most of the time they are set dry and then this happens ! NO BIGGY !
