-   -   bleeding hydraulic rams on bravo one (https://www.offshoreonly.com/forums/drives-lower-units/254224-bleeding-hydraulic-rams-bravo-one.html)
pagerboy 05-23-2011 12:29 PM
Do you have to bleed the rams after you remove them? I had one that was bent. I took it off the boat and had it repaired. theres no fluid inside the ram now. was wondering if there was a procedure to reinstall?
mr3dman 05-23-2011 12:33 PM
All you should have to do is cycle them a few times and keep an eye on the fluid when trimming up to make sure you dont empty the resirvior.
Knot 4 Me 05-23-2011 12:48 PM
+1. Had to do this last year after rebuilding a ram.
1MOSES1 05-24-2011 12:45 PM
+1 here...just did this a couple weeks ago. same process for trim tabs too.
