-   -   Bravo shifting question (https://www.offshoreonly.com/forums/drives-lower-units/254994-bravo-shifting-question.html)
wayne272 06-02-2011 08:03 PM
Stbd drive shifts fine at idle and slow speeds. After running hard and trying to shift stbd drive into neutral, shifter will only go to neutral using a little force. Port shifts smoothly. Replaced cables over the winter (same problem before change). Any ideas?
firehawkcat 06-02-2011 09:08 PM
What kind of drive??
waconda 06-03-2011 07:10 AM
Sounds like maybe your brass bump rings are worn.
JaayTeee 06-03-2011 09:29 AM
+1
wayne272 06-03-2011 12:21 PM
B1's
obnoxus 06-03-2011 02:20 PM
swap drives left to right
wayne272 06-03-2011 06:53 PM
Good idea but I have to swap the upper's back covers since I have imco steering.
