-   -   Trim Pump: Dead? (https://www.offshoreonly.com/forums/drives-lower-units/256461-trim-pump-dead.html)
cash68 06-23-2011 03:52 PM
Trim Pump: Dead?
My trim pump was working fine. I have the old style with the reverse lockout valve. The other day, as I was coming into the river, I could not trim up my drive. I banged on the solenoid, and kept pressing the button. My exhaust is REALLY REALLY loud, so I could not hear it working. I got halfway into the river, checked the fluid, and it was gone! I didn't realize it was dry! I added some fluid, and it "kind of" pulled the drive up, but then stopped. Also, the motor sounds godawful now. instead of a high pitched "whir", it sounds lower pitched and uneven. What could be wrong?
John the Drive Man 06-24-2011 07:55 AM
Need a new pump, You can buy a new one cheaper than trying to fix yours.
1MOSES1 06-28-2011 07:29 AM
probably burnt it out trying to push air...
ken sampson 06-28-2011 08:13 AM
I have two older stile for sale. $100.00 each
Ken
cash68 06-28-2011 10:24 AM
The inside was filled with tan goo/oil water mixture. Cleaned it out, motor sounds pretty good! Going to reassemble tonight and see if it works!
