-   -   xr seals how much??? (https://www.offshoreonly.com/forums/drives-lower-units/257317-xr-seals-how-much.html)
powercat 07-05-2011 08:05 PM
How much are you guys paying to have new seals installed in your bravo drives? I have an xr drive that I'm having torn down and was quoted $600 to have resealed. That's just for seals, not saying its to much I just don't know.
sac 07-09-2011 09:51 AM
That would be a good deal!
JasonSmith 07-10-2011 12:40 PM
The hardest part of that job is taking the drive off to replace the drive to gimbal housing seal. Other than that, split the lower from the upper, replace 2 o-rings, pull the prop-shaft carrier, replace one o-ring & one seal.
$600 is pretty steep for $25 worth of parts & 2 hours of labor.
powercat 07-10-2011 01:07 PM
drive
Quote was for $600 and I have already have the drive off. I found someone who is going to do it and inspect gears for $250.
BDiggity 07-10-2011 04:03 PM
Damn! I guess next time i will do it all myself & save $1100. But i also had new bearings & gears put in.
