jr marine gimbal kit
is the plate that covers the hole in this kit machined for an o ring seal or is it just a flat plate ? thanks
Step 14 says there is a gasket.
http://www.jrmarine.com/instructions.htm |
It is a flat plate that uses a gasket
It is a flat piece of polished stainless with a rubber gasket the is the same size as the plate. Just did it to my Dad's boat.
I've done it too, its a great kit and much easier way than the merc plugs!
I also put sealant around the bolt holes and engraved the Baja logo into mine before installing it. It looked pretty damn trick! |
Go with JR's hit stay away from Merc's plugs
JR's kit that is
ok thanks. bought one. i still think it looks a little hackish but its better than pulling the motor and transom plate off. i cut mine today and i would not have been able to get to the top nut even with the motor out. i still would have had to pull the plate off
That cover plate kinda make me question it's reliabilty to seal.
Rather have a leaky seal than a leaky cover plate. A buddies boat has 2 leaking seal. I'm talking him into either pulling the motors or use the Merc kit. Too much of a risk for a boat that lives in the water. |
| All times are GMT -5. The time now is 11:16 AM. |
