-   -   baja 272 drive heights???? (https://www.offshoreonly.com/forums/drives-lower-units/260195-baja-272-drive-heights.html)
zeke 08-13-2011 09:24 PM
i was thinking of going with a Imco SC on my 272, would there be an advantage to going to a 1 or 2 inch short lower?
articfriends 08-15-2011 12:27 AM
How fast do you run, it did NOTHING for my 2000 272 , My prop center line is at 7.5" and I am running 1000 plus hp/ft lbs of tq. My boat lost top end, tried to swap ends and couldn't hold plane or take trim with -2 shortie, I tried a 1" spacer before giving up, still sucked, I am sticking with stock drive height now, Smitty
A.O. Razor 08-15-2011 09:09 AM
Never go with the 1 inch. You can always space down. From what I understand, the XR will most likely slow you down, if your not running big power and high speed. Also, some say the IMCO SC lower is much better for the v-hull than the XR shorty. Like Smitty said, what are you running and what is your exact setup?
zeke 08-15-2011 09:48 AM
Im nothing spectacular yet. i was hoping to see smitty respond to this post cause if anyones played with a 272 its him.
I just have a 450hp 454 running 64 on gps with a 23 mirage @5000 rpm. Imco single ram steering, HP transom assembly. I Live on a small lake about 1.5 x 12miles so its never ran hard for real long
My drive is cracked and insurance is gonna be buying most of my drive so im debating on what drive i should buy.
And planning on 650hp in the near future
articfriends 08-17-2011 02:53 AM
for 650 hp you could easily get a stock xr or even a x to live with a 4 blade labbed, it will slow your boat down slightly for now, I wouldn't worry about changing drive heights for now, with a shorty you will need other mods like 5 blade props and once you drop the slip with one you will probably break drive stuff even at 650 hp, Smitty
zeke 08-18-2011 06:46 PM
smitty what do you think about the teage marine drives? i can get one for 3800 with 30 hrs on it
articfriends 08-18-2011 07:34 PM
Depends on what it was ran behind and how many hours it REALLY has, 30 hours behind 1200 hp could mean its been blown up 4 or 5 times and patched back together, it could however be like brand new. As far as the quality, a mixture of xr parts with a few shafts that are better as far as I know, Max worx does the most mods but they are 10,000$ plus new also, Smitty
