| offshorefisher |
08-17-2011 01:08 AM |
bravo 2 stuck in forward gear
I've searched a few posts, but haven't found exact symptoms. My drive will periodically hit neutral and reverse, but it mostly runs in forward wherever the shift lever is. Shifting by hand (cable) is the same. Sometimes I can find neutral and reverse, but most of the time, the drive stays in forward. What do you think is broken? Lever, cone, etc? As the drive will hit neutral and reverse once in a while, it seems like it shouldn't be "welded" right?
