-   -   #3 drive spacers (https://www.offshoreonly.com/forums/drives-lower-units/261506-3-drive-spacers.html)
bigboat28 09-01-2011 11:14 AM
#3 drive spacers
Is there spacers for the #3 drive?
A.O. Razor 09-01-2011 01:11 PM
Yes I think there are. Maybe Bam can help you.
John the Drive Man 09-01-2011 01:14 PM
Yes we have some. But you may have to change out the vertical shaft. Call us at 954 237 0332
RMPRam 09-01-2011 07:44 PM
I don't think that I have ever seen a spacer for a #3 drive, let alone a "longer" vertical shaft. I would like to see either of these.
DareDevil 09-01-2011 07:46 PM
I AGREE !!!!! never seen any of both or heard of them !:party-smiley-004:
tcelano 09-04-2011 01:45 AM
OK, I'll bite. Why would you want a #3 to go any lower that it already is? It already runs mostly submerged, which isn't ideal for the cleaver props.
You'd be much better off with a little bigger propeller, or a different rake angle if you are looking to change bow lift characteristics.
The other thing you could do is add extension boxes or notch out the hull/transom. That will have a similar effect of making the drives run a little deeper.
Mbam 09-04-2011 08:46 AM
Back in the day Kiekheafer (when it was a seperate company before the Mecury purchase) made a non-torsional shaft that was longer. I seem to remember spacers too.
Back then there were not very many prop choices.
rhinoLX 09-04-2011 06:41 PM
I started work at Lake X in 1985 just as Mercury was chopping down III's in preparation for the release of the IV drive. I've built a few of those welded III's myself and installed some Yo-Yo blocks (spacers) as well.
P.S. Set the way back machine Mr. Peabody. LoL
P.P.S. If you're under 50 you may not recognize that line. LoL
John the Drive Man 09-06-2011 09:24 AM
Yes Kiekaefer sold a complete kit with longer front vertical shaft. I still have some. If interested call; 954 237 0332
RMPRam 09-06-2011 11:37 AM
I stand corrected. I did not realize that there was such a kit.
