NXT drive oil Amsoil?
What weight if I want to switch to Amsoil in NXT's
What does Mercury call for? I can find out from there.
75-90 severe duty
Run either the Severe Gear 75w90 or the AGM Marine Gear Lube 75w/80w-90.
I was recomened to not use the "marine" gear for my SSM 5's. It says high performance on the bottle, but not the type of HP that we are talking about. I run the amsoil severe gear 75w90 per Teague's recomendation. I only have have one light season on the drives but it seems to be working well for me.
These are NXT's similar to #6 dry sumps. In merc its Super+ gear lube, Amsoil is perhaps the same as a #6 ??
What Amsoil product in my SSM III?
severe gear
I was at a amsoil dealers home today and he has signed pics of Bob Teague and the amsoil cat all over his shop. He also claims bob runs amsoil motorcyle oil in his drives! |
the 75/90 severe gear? Should I also add the Lucas Heavy Duty Oil Stabilizer? I believe my outdrives hold almost 10 quarts a piece. DANG!!!
a lot of knowledgeable people use the lucas additive...i did in my bravo....jmo
in all drives you can use the amsoil severe gear 75-90w and mix it with the lucas additive for best results,,,,4qt amsoil to 1qt lucas
I can't find it now but somewhere there is a SAE standardized test of Amsoil Severe Gear and most of the major synthetic gear lubes and the Lucas did not fair well at all. It was on the bottom end of the scale, kind of surprising considering how many OSO'ers use it. I have it in PDF if anyone is interested, it's one of the most extensive tests I've ever seen on gear lube.
LUCAS gear lube probably isnt the best... the Lucas engine additive mixed with amsoil sever gear covers all areas of protection for your gears
I think I will give the Amsoil severe gear and lucas blend a go rather than try the Amsoil marine Gear lube
Amsoil Marine is better then a mix of Amsoil Extreme and Lucas. You don't dilute your gas, don't dilute your oil.
amsoil marine is not better than amsoil severe gear .per amsoil themselves...and your not diluting it,,, its like putting stabil in your fuel,,,,all the lucas does is increase the properties of the gear oil that are most important for keeping your gears alive....there is a reason why max machine and others repackage this formula,,,,bc it works,,,just my 2c.
The Lucas additive is ABSOLUTELY NOT needed! If AMSOIL wanted their gearlube to perform with excessive drag on the gears they would make it that way to start. The Lucas will cause a condition called fluid friction which in turn will increase the drive temps. The AMSOIL Severe Gear is ALL you need, period.
Originally Posted by offshorexcursion
(Post 3507093)
severe gear
You don't want a thicker oil you need a better oil one that flows and protects at the same time. Stop and think about where Nascar and car manufacturer's have gone with engine oil, 0w or 0-20w and it still works and better fuel mileage and more power. The oil industry has changed but they forgot to tell the consumer.
Kind of an old thread, but I found it doing research for Bravo III lubes.
When adding Lucas, or whatever, to the drive lube, how do you do it? Do you mix it in a container and pump it in or add some of the main lube, add the additive, and then top up with the main lube? I assume it will mix together in the gearcase, but if I add the additive first it will be concentrated in the upper end or reservoir and not in the lower part where the gears are. |
I use a different mix, but I mix then pump. That way it is fully in solution at the correct ratio. Then just pump what volume you need.
Originally Posted by SFOcean
(Post 4164188)
Cheers! |
Originally Posted by 07DominatorSS
(Post 3508913)
Amsoil Extreme Gear is what Bob Teague is running in his 6's, check out his latest press release. Don't dilute your Amsoil with other additives or oils, if you study the test data you won't do it. http://teaguecustommarine.com/teague...r-in-st-clair/ |
| All times are GMT -5. The time now is 11:47 PM. |
