-   -   Repowering, Need Suggestions on Drive (https://www.offshoreonly.com/forums/drives-lower-units/262865-repowering-need-suggestions-drive.html)
Moparcrazy.com 09-23-2011 05:58 PM
Im saying so long to the 496HO. The motor has given me 140trouble free hours. I want to go faster then 65-67. Im going with a 650 to 700 N/A motor. Im waiting on estimates from various builders. I have a Bravo X drive. I realize I need to upgrade. Im asking advice on what would be the most economical way to upgrade my drive. Im running a 2004 Checkmate 270 O/B. Thanks, Darrick
Chris 09-23-2011 06:18 PM
imco
weldcrane 09-23-2011 06:51 PM
imco SCX
waconda 09-24-2011 06:43 AM
Your best option is a Bmax By a Mile!
TRL505 09-24-2011 08:20 AM
Originally Posted by weldcrane (Post 3510850)
imco SCX
Prob dont need an SCX with only 650HP...but it wouldn't hurt. You could go with an SCX upper and SC lower. Given the fact that your boat is only a 27..that helps things quite a bit.
Good luck!
Who are you getting quotes from on the engine??
offshorexcursion 09-24-2011 08:29 AM
I would go with the SCX or scx upper sc lower. I would also go with 700-750 hp N/A just cause!
You should talk to Dick aka Mr. Gadgets. He knows alot about drives and checkmates. I hear he is putting big power in a checkmate similar to yours with a full SCX outdrive.
we all look forward to pics!
616-403-1006
Moparcrazy.com 09-24-2011 12:27 PM
1 Attachment(s)
Thanks for the info guys. Im looking into Ateco, Sterling and Cobra. Trying to use a builder close by.
TRL505 09-24-2011 07:01 PM
Nice.....
AIR TIME 09-24-2011 07:32 PM
no way on the chit max I've seen more blown ones on a few boats with 700 to 750 hp. imco scx upper with sc lower shortie or konrad ace xfactor. if your easy on the the drive a b1x built by Mr Gadgets on here would be the best deal. I got years out of my b1 drive about 16years at 1st it had a 454 330hp, then a 502 390hp also a 585hp for 2yes a 595hp 2 yrs a 509 with 650hp. never had a issue plus I put a late model used b1 with a imco shortie but it was stolen. next was a b1x but I sold it and bought a konrad ace xfactor which has 1100hp in front of it. the b1x is a nice drive with a full tower inside of it like the xr.
AIR TIME 09-24-2011 08:01 PM
if you want agreat motor call DEAN GELLNER in clev ohio #216 398 8500 thats the shop #. he is a real builder that does all the work and knows what make hp that lasts. his motors have won many races in cats and vees also 2 teams were key west champs in the same season 2 yrs ago.his motors are outerlimits boats in the passed. he has been in pbm more than once. he is the real deal in your area. the others are good I know one or 2 of them have guys doing the work while there in the office. call him and talk to him see what he can do for you. I know your motor will hold up the best with him. anyone can buy a block wip parts in it but a true master builder does his magic to the block and heads where oiling makes a big different. he built my motor to run on raw water =cold so when I asked if I if it made a different if I went closed cooling he said YES. others would not cared. so even if you just talk to him you will see a differents. good luck
