-   -   Sage #8 vs. Merc #6 (https://www.offshoreonly.com/forums/drives-lower-units/263640-sage-8-vs-merc-6-a.html)
TeamPSI 10-06-2011 10:51 PM
Sage #8 vs. Merc #6
Hello everyone... does anyone out there have experience with these drives?? Pros vs cons??
Philm 10-07-2011 07:13 AM
The only Sage boat I have seen on here was a Superboat Y2K with a single turbine mated to a Sage 8. It looks like a fantastic drive for our purposes, but he had trouble getting it to work in a single application. Cant imagine the cost of it. Plus, it is HUGE. Like incredibly massive. But it has a changeable X dimension and trim, which is pretty interesting.
Totally different drive than a #6. Alot of guys on here with #6 experience.
John the Drive Man 10-07-2011 08:38 AM
The only difference from #6 to #8 is the lower heavy duty only. Upper has same parts as #6. Same Trasom assy. lower housing assy. heavier. Otherwise no difference/
cougarman 10-07-2011 08:40 AM
Dave Wesseldyke used them on his boat.
http://www.wescoracingengines.com/
616-662-2250
Also Jim Dyke Used them and last I knew still had a pair in his shop he may part with ?
http://www.airshipribs.com/airshipcms/
866-967-1073 0r 440-967-1073
Good Luck
Jon
John the Drive Man 10-07-2011 08:41 AM
Should you have any questions call me at; 954 237 0332
cougarman 10-07-2011 08:41 AM
I think you may be refering to the Mercury #8,.......not the SAGE #8 ?
Jon
John the Drive Man 10-07-2011 08:48 AM
O you are correct. Thanks I wasn't thinking the Sage 8 is a different drive. Thank you.
TeamPSI 10-07-2011 12:57 PM
Thanks for the info guys!! I bought a pair of the drives off of Jim at air ship ribs... that is why I started the thread. Just wanted to see what the general thoughts were on the board... (good experiences? bad experiences?)
I have a 47 Fountain Flat Deck... the green, black, and silver one... it looks like these drives can take some real power.
Right now my transom is solid... I could go with standard twins... or put a third motor back in it... but then I am stuck trying to find another Sage #8. I think staggering would be too costly at this point... but I could be wrong.
Thanks guys!!!
Q
cougarman 10-07-2011 02:22 PM
Thanks guys!!!
Q
Been a long time since I was at Jim's Shop.
But if memory serve's me seem's like Jim and his
Crew improved a few little quirks they had.
Seems like the only other thing I remember was after sitting in the water over a weekend of racing etc. had to pull the plug and let the water out.
Didn't sound like a huge issue,........just something to be aware of that they can leak a little bit inside.
Personally I would ask Jim about it,...if he didn't already go over it with you.
Dave Wesseldyke likes his from what I remember
Both are great guys to talk with and won't BS you.
Other than that I think info will be hard to find, very few of these drives out there.
FYI #6 drysumps take on water too.........
Jon
A.O. Razor 10-07-2011 03:07 PM
Does SCS still build this drive? Should ba as strong as the ASD#8.
