-   -   SSM question? (https://www.offshoreonly.com/forums/drives-lower-units/265010-ssm-question.html)
rob vanharten 10-31-2011 10:03 AM
SSM question?
So has anyone herd of a #4 A? I picked up a set of #4's, and they are the big shafts drives. But they also say on the drive #4 A? Did these have different internal's other than the big prop shafts, like the 3A, and the #5? Any insight on this would be appreciated!
MILD THUNDER 10-31-2011 11:20 AM
Sounds like your basic #4 drive with big propshafts installed. I dont believe anything gets changed other than propshafts
RMPRam 10-31-2011 05:03 PM
Mild Thunder is correct. I believe that you could get a #4, from Mercury, with the "big" propshaft. I have new sets of straight cut, near net forged, polygoned upper gears available for the #4 in case you ever need to replace the spiral cut gears that were std. in a #4. The gear that I have is the same gear as a #5 with the "shank" of a #4. I also have "big" propshafts and lower gears available for a #3 or a #4.
Gary Kollofski
612-247-7081
rob vanharten 10-31-2011 07:33 PM
Thanks for all the info guy's, its much appreciated! Gary your number is in my phone, in case the need arises.
