-   -   can 365hp hurt a bravo 1 (https://www.offshoreonly.com/forums/drives-lower-units/266336-can-365hp-hurt-bravo-1-a.html)
tnc110 11-27-2011 09:33 PM
can 365 hp hurt a bravo 1 on re-entry if not throttled down?
FIXX 11-27-2011 10:04 PM
fixx
depends on how heavy the boat is,,a buddy hurt his witha 23' baja dvx same power with a 3 blade mirage..the chances go up if you have a 4 or 5 blade prop..
bunky1957 11-27-2011 10:27 PM
yes
When I bought my 311 it had 800 hrs, 365 mags and 3 blade 23 Mirage props.I had to replace the driveshafts when I rebuilt the drives because they were really twisted.
NightHawk 11-28-2011 05:49 AM
I have an original 1992 Bravo on my 23 foot Checkmate. used to be a 330 HP 454. Has a 425 HP 496 now for 6 years. Both 3 and 4 blade props over the years. I'm not gentle with it. My throttle has two positions with lots of air time.
I do have a drive shower but they seem pretty tough to me.
tnc110 11-28-2011 09:56 AM
25zx 3 blade mirage plus
I would assume that if you come out at or near the rev limiter then you have less of a chance of hurting anything...
machloosy 11-28-2011 10:08 AM
You can hurt a bravo with that power if it isn't driven right, even with less power for that matter. A lot of air time is tough on anything. But that is near stock power and those bravo's are common and wide spread for a reason. Do your best to match the prop speed on re-entry and she'll live for years with routine maintenance. If it's on your Donzi, that is a little heavier boat which will have a factor in the amount of wear.
