-   -   Drive ratio (https://www.offshoreonly.com/forums/drives-lower-units/266711-drive-ratio.html)
winkman 12-04-2011 05:43 PM
Drive ratio
How can I tell what ration is in my B1?
A.O. Razor 12-04-2011 07:52 PM
1 Attachment(s)
Check the port side of the upper case. If your decals are original and still there, it will be stamped on the port side. If not, you can use the serial number and call Merc.
winkman 12-08-2011 03:13 PM
Thank You!!
