gimbal bearing
im about to replace my standard bravo 1 with an xr...i know i have to change the gimbal bearing...someone has the part number for the bearing? anything else i need? is this bearing a merc-only part?
thanks |
If you have a RED dot bearing and its fine, you do not need to change it.
You don’t have to worry because Merc only sells one now, a non grease-able bearing.:eek: |
You can order a 18-21005 red dot from Sierra marine. It still has the grease fitting if you want it.
thanks,guys
What brand is the Sierra bearing?
| All times are GMT -5. The time now is 09:14 AM. |
