gimbal bearing
have to change my gimbal bearing...are they all the same,quality-wise,or should i stick with the merc one $$$?
i know sierra has one also...going from a b1 to an xr... thanks |
If you are going to the expense to change the drive buy it from Merc. They only make one now, so the selection is easy.
Also when changing from Bravo to an X or XR you need to add spacers to the trim cylinders and depending on the year, you might need to change the ring that holds the ujoints bellows. The spacers and ring is less than $15. I posted the service bulliten for this last year. Do a seach and you will find it. |
thanks,jim
| All times are GMT -5. The time now is 02:38 AM. |
