Bravo Low Water Vs Side Water Pick up
Offshoreonly Advertiser
Low water pickup is something you don't want unless you need it. Prone to picking up sand, mud etc. As Poker says depends on drive height. The standard Bravo has had dual pickups for years, both bottom and side. For marginally high mountings you just plug the top one or two holes.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
I had the standard bravo lower with dual pick up with no issues. I recently changed to an IMCO lower with only low water pickup and have some issues. I did however install a sea strainer at the same time as the IMCO lower. I due drive in some shallow areas and have found that on busy weekends when some sea weed gets stirred up it gets caught in the sea strainer and restricts flow....if I suck any sand up at that time it packs the sea strainer full as it cannot pass thru with the sea weed on the screen.
Stay away from low water pickup if you can, or plug the openings. Those things are like sand shovels and only necessary for high drive heights. Can't use elephant ears to flush with LWP either.
I thought you were sticking with Alphas? Much less to worry about IMHO.
BTW...you don't happen to have a Bravo/Alpha Gen II transom drill template I could borrow laying around do you?
I have a lot of slop in my gimbals....have the engines out anyway. With 400 Ft Lbs + and over 350 horsepower...vs the price point fall on Bravo equipment....+ the reliability...decision time....lots of pluses on the Bravo side. Bravo Transom assemblies will be here this week.
Xcal24 (11-23-2023)
