mercruiser- pre alpha drives
found a 233 formula with twin 250 inline 6 cyl, mercruisers mated to mercruiser drives (pre alpha) 1970's). plan on rebuilding engines, purchasing current alpha drives , new transom assemblies etc. Is this something that can be pieced together?
hate to saay this but the older uppers are way better hsan the gen2's seen a lot of blown late models an no earlys
Originally Posted by kubelwagonman
(Post 3596006)
Cut out is the same except for 2 additional holes. Will need to use new style flywheel housing, coupler and exhaust pipe. Most likely will have to make something up to get the exhaust to match up. Should work OK. Oh - new style trim pumps and shift brackets also.
thanks all.
| All times are GMT -5. The time now is 02:53 PM. |
