X Power Drive .... X-Power Drive ....XPowerdrive
#31
Food for thought a number six drive assembly weighs 645lbs and on our dyno consumes almost 90 hp to turn it 7000 rpm. The Bravo drive consumes 44 hp @ 7000 rpm and weighs in at under 65lbs. The X Power Drive consumes 11.5 hp at 7000rpm, and we have had versions that consumed 9.5 hp at 7000rpm but have now settled on the 11.5 hp at 7000 rpm version. It weighs in at 202 lbs. The drive has 254 parts inside which is far more than a bravo hence the increase in weight, also the parts are far larger to handle the increased power and torque. Okay now on to the price.
Bill Auberlen
CEO X Power Drive
805-320-5631
Bill Auberlen
CEO X Power Drive
805-320-5631
I applaude your efforts, it would appear you have come up with a spectacular product. With that said, I have a couple of questions...
First, while your loss numbers are impresive, loss is also expenential with rpm and your ratings are at a staggering 7000rpm. Very few engines spin these numbers. Would you mind sharring the same data at say 6000 rpm, which is closer to what most users would see in real world usage? My guess is the delta on those losses drops significantly.
Second, you mention your drive has a lot more parts. While your testing has shown them to be very robust, more parts also means more things to go wrong in the future. Maybe not today or tomorrow, but maybe ten years from now. As you've stated, you have a lot of very expensive and custom parts in these drives. God forbid you get run over by a beer truck tomorrow, but in the event you do... where does that leave the customer 5 or 10 years from now when he needs one of those exotic parts??? I'm no huge fan of Merc, but at least I know I can get parts for a #6 20 years from now.
Again, fantastic work and very impressive product!
#32
Hey Bill,
Love the video.... It is very interesting to see that view of the drive, prop, and water.
I'll be designing a newer version of our Hyperdrive Offshore prop later this Spring for the #6 propshaft.
It will be available in 3, 4, & 5 blade configurations.
Thanks,
Tim Bostic
Thanks,
Tim Bostic
#33
#34
In a staggered setup rear engine forward one inch and potential vertical adjustment. in my case there's not much room to move to move forward and would likely require moving both; the port engine has no room to move forward or down without impacting bulkhead step.
#36
#37
Your drive is really a well thought out package and your auto endurance racing background I am sure played a role in it's design.
In the future I may be looking at your drive or Imco SCX. I have raced Bravo boats for years so I will see how long these last me.
Steve
#38
Are thees drives out there ? has it happened ? the web site seems ok but not updated and no actual installation photos considering the time line . This is the best of all the attempts i have seen on the WWW and a lot of European and Uk boat shows i have been to in years.It would be a terrible shame if it turns out to be a non runner .
Ricardo Mann
Ricardo Mann
#39
I know several 32' Spectre's are running them (I believe one or more are owned by the creator), but there aren't many others around that I know of. Too bad, the drive looks very promissing! I could be wrong, but I suspect cost has kept sales volume low.
#40
If you need references I can put you in contact with existing customers.
If you need any help please feel free to call.
Bill Auberlen
805-320-5631
