Need drive help on a warlock project.
I am new to this site and I was wondering if I could get some information on what would be the best drive and prop. I have a warlock 29 world class and I will be using a cummins ISB Engine the engine has about 600 horsepower and 1200 Lb ft of torque. What drives will take that kind of torque? And is there a prop that would work with only being able to turn 3500 max. Thanks
You are going to need at least a BMax or SCX to handle the torque unless you go with a SSM6 and trans. You are going need a huge pitch prop and the boat is probably gonna idle at 12-15 mph.
The other option is a 2 speed trans and #6 drive or Arneson. You are looking at probably 20-40k. |
Originally Posted by cumminswarlock
(Post 3615435)
What you want to run on that thing is an ASD#8-6 and a two speed tranny. For the diesels to work well, you need prop speed and a shiftable transmission, so you can get up on plane. With 1200 lbs. forget any kind of Bravo drive, whether it being Bmax, IMCO, Konrad ect. Get something efficient, the ASD#8-6 rated for 1500 ft.lbs.
i have a bmax if you can use it i will take 3000.00 for all the bmax stuff i have 405-640-1491
bmax holds up pretty well as long as you dont kill it from take off
(Post 3615435)
With the Arneson you get a warranty as this is an easy application. |
go arneson or don't waste your time with the project!
Keep us updated though with lots of pics! I love diesel go fast boats! |
600 hp out of a 5.9 cummins B series? they have a rep for having short lifespans at 350 hp.
