-   -   Is this a TRS? (https://www.offshoreonly.com/forums/drives-lower-units/271062-trs.html)
corvetteman 02-20-2012 03:58 PM
Is this a TRS?
I have an outdrive that i believe is a trs. The serial # is 4521589. It is currently on a 27' century behind a 454 330. Whats the difference between trs 280 & 330? Any help is appreciated.
outonsafari 02-20-2012 04:21 PM
trs
http://bluewatermarinesvc.com/pdf/dr...year_index.pdf
on here says its a trs.
Clustergear 02-20-2012 07:44 PM
280 was a 350 ci with TRS 1975-76
330 was 454 ci
Mbam 02-21-2012 06:15 AM
Could also be a TR on that style boat. How big a prop can it swing? TRS is 16" max, TR is 20".
Same upper unit, differant lower.
Clustergear 02-21-2012 06:20 PM
The serial # listed is to old for a history, but it falls into the TR range in the EPC (Electronic Parts Catalog)
Does the bullet area where prop shaft and carrier are look to be the same diameter as a Bravo or Alpha than a TRS if its bigger a TR. TR has also has bigger prop shaft.
