best place to buy outdrive kits
working on pre alpha,s with accordian bellows all my bellows look fairly new with no cracking but i have one bad gimbal bearing and slight water intrusion in the other driveshaft bellow
i assume someone replaced all the bellows not to long ago and that was all also need lower shifter cables any one know a good source for the kits priced right ? also the drive with the bad gimbal bearing has alot of fresh gear oil in the driveshaft bellow im assuming that there is a bad shaft seal causing that ?? i checked the impellers on the boat and topped the fluid up on both drives so i know it came from me |
any one ever buy anything from these guys
http://www.marine-shiftcable.com/im519.htm |
That w/site is a side site to amarket.com. It has only cables in there but the amarket.com is the main site. We have been in business since 1968. The bellows kits are at this site. click tab PARTS BY LIST then click BELLOWS. Kits are for all types, you must know if you have a standard #1 or Alpha, Alpha gen II, or Bravo. The kits come with no bearing, bearing center only, or complete bearing.
Thank you for considering our company for parts. |
| All times are GMT -5. The time now is 02:32 PM. |
