Bravo 1 vs Bravo 1 X
What is the difference between a 2001 bravo 1 and 2003 bravo 1 X?
Mainly the steel tower in the upper case. A steel tower can be added to your B1 if desired. The upper case for the B1 X is an XR upper, it has the larger retainer for the pinion and consequently is thinner in that area. The 2001 should be an OM drive and have the X gears in it, just like the B1 X. Input shaft is the XR style (larger ujoints), so the X gears are actually the same as the old XZ drive. Only difference between the X and XZ gears is the ID of the pinion gear (it is larger to fit the larger input shaft) As the chart that Griff pointed out, shows.
Dick |
So what would you do? I have both drives, I just bought the Kachina with the X drive. When I changed the oil I found 2 small metal pieces on the drain plug magnet. The motor has 425 hp. I have a bravo 1 on another boat that has low hours. Can I switch them and not harm the outdrives? My other boat only has 300 hp.
The X drive would be the stronger of the two. But at 425hp and driven with respect, the B1 should live a long life behind that motor. That being said, you could look into the X drive to see where the metal came from, more than likely the lower gears are starting to pit, get it fixed and swap back, keep the B1 for a spare, if you wanted.
I would not be afraid to run the B1, driven with respect ( no hole shots, easy on plain, no WOT till you get the hull aired out, and timed throttle back on exit and reentry of the prop). Hope that helps. Dick |
Thank you.
| All times are GMT -5. The time now is 01:02 AM. |
