-   -   Merc #6 Drive Failure Factory Problem (https://www.offshoreonly.com/forums/drives-lower-units/273737-merc-6-drive-failure-factory-problem.html)
bcfountain 04-11-2012 11:10 AM
for what you pay for merc stuff,it should be covered.
AIR TIME 04-11-2012 11:35 AM
Originally Posted by UrbanDisturbance (Post 3656819)
I am so glad I am getting my boat converted to Arneson Surface Drives... Good Luck!
far better than merc, I went to a konrad myself. the scx looks like a nice drive to. hell with merc.
29Fever575sci 04-19-2012 08:40 AM
Merc does suck!!!
New rebuilt drive with XR gears, one tooth broke off after 11 hours easy use. Merc would not cover. Rebuilt again with XZ gears because of issues with the single gear tooth breaking on the XR gears and the pinion gear went after 2.5 hours. Tested the pinion gear hardness and it was real soft so they had a quality problem with the heat treat operation. They did cover that set but I had to prove the gear was junk first. Problem is I had to pay for all the rest of the crap that was screwed up due to the gear breaking, new bearings, clutch shaft, bearings..., not cheap and all they would cover was the gear set.
articfriends 04-21-2012 11:41 AM
Yeah, what is anew #6 trans, transom assembly and drive-45,000??
