-   -   Speedmaster drives (https://www.offshoreonly.com/forums/drives-lower-units/275267-speedmaster-drives.html)
bigboat28 04-26-2012 12:40 PM
Speedmaster drives
What fluid and how much does a tranmission for a number III drive hold? Is it just ATF fluid?
excalibur82 04-26-2012 12:53 PM
Use the merc high performence and 2.5 gallons of oil...
OldSchool 04-26-2012 01:00 PM
Not in the transmission!!! :eek::party-smiley-004::poopoo:
RMPRam 04-26-2012 09:02 PM
Most, if not all high performance marine transmissions use type F ATF.
MILD THUNDER 04-26-2012 10:41 PM
Type F transmission fluid in the tranny.
excalibur82 04-27-2012 07:48 AM
OOOOOPs thay thought he said drives...:lolhit:
tcelano 04-27-2012 01:23 PM
It all depends on how big your cooler is, and if you drained it, etc. I just filled one of mine from dead empty, and it takes about two quarts initially. Then you fire it up, and set the level while it's idling. It might take another half-quart or quart.
Type F.
CP Performance has some special Borg-Warner fluid I see, but I haven't tried it.
tcelano 04-29-2012 01:38 AM
Just confirming. I fired mine up yesterday, and the tranny took all of the third quart. It is a Huber 1450 with a 3"x 18" cooler.
MILD THUNDER 04-29-2012 07:09 AM
Curious, why such a large cooler? My huber paperwork for my 1200's recommended like a 2"x9" cooler. I think bam recommends the same for the cyborg trannys. Might be 2x8, or 2x10, but it was fairly small. I think you wanna get a little temperature in the trans?
catinaround 04-29-2012 07:19 AM
WOW 2.5 gallons in the transmission you say :eekdrop:
use Type F
tcelano 04-29-2012 08:02 AM
When I started the project, I planned to use the stbd 8-plate bellhousing coolers for the transmissions. Mid-course, those became fuel coolers. I happen to have one of the big coolers in chrome, with the small section on hand, so that became my transmission cooler and power steering cooler. I got another log for the port side. They seemed like good replacements for the plate cooler. Might be overkill, but I figured cooler was better. I've got temp and pressure senders on the trannies. If it looks like I can't get any heat in them, I'll try to find some thermostat bypasses that work in the 130 range.
