-   -   trs check valve seal (https://www.offshoreonly.com/forums/drives-lower-units/275893-trs-check-valve-seal.html)
mookster 05-06-2012 03:43 PM
the check valve on the drive is fine. the one on the bellhousing was missing when i got the boat. id like to fix it.
Are the part numbers the same for both drive check valve and seal and spring as the bellhousing one???
picklenjim 05-07-2012 12:31 AM
Yes they are.
Drive parts 11-12-13
http://www.perfprotech.com/store/ass....aspx#assembly
Bell Housing parts 7-8-9
You will probably want to get the seal, part number 2 for the bell housing also.
Biggus 05-07-2012 06:09 AM
I'd buy 2 seals as unless the two surfaces (drive and helmet) are parrelell, it's very easy to bend the seal. If it's bent, it will leak.
mookster 05-07-2012 07:12 AM
so i did order the right parts. you must have to hold the bell housing up in tilt mode to but them in from the backside?
c_deezy 05-07-2012 10:04 AM
Yeah easy to nick that seal while putting the drive on. I used to keep a couple extras around, rub a little grease on it as well to keep it from ripping and help it seal.
