Speedmaster drive ?
Hey guys,
I've never really messed around with the Speedmaster III or IIIA drives. My question is can someone school me on these drives?? Like what their hp rating is, how the transom assembly is different, the difference in gear ratios, just anything about these drives. Thank you guys. Gregg |
The 3 and 3a drivea are generally good for 800 hp or so. Some people put more through them. The 3a has a bigger shaft. They are discontinued so parts are tough. Talk to Speedmasters inc in Florida. They know these drives.
Wannabe |
Thanks bro, I appreciate it.
Originally Posted by wannabe
(Post 3695900)
Wannabe |
+1. Listen to Gary. He knows these things. I had a set of upper gears taken out of a SSMIII that had run 850 hp, and they had broken a couple teeth already.
SSMIII was "Capable" of 800+ in a racing environment with frequent rebuilds and attention. In everyday use, it's probably more like 650-700. It will still outlive a Bravo though, and they fare much better pushing big heavy boats. If you are in the market, IIIA and V's are still viable drives, and will get you more drive for the money than pretty much anything else. You can scavenge III transom/gimbal parts, then just bolt up a IIIA leg when you can find it. The other weak area of the III/IV was the trim pins. The original was a rather absurd (my opinion) staked design. I've retrofitted a total of three #III gimbals with IIIA/V style pins. It takes a bit of machining, but well worth it even if they havent gotten totally sloppy yet. Going back to the original post- III's and IV's are based off the same hardware. Virtually everything was the same except X-dimension and cases. These had the 1-3/8" 19 spline shaft. It is hard to find four-blade props for these. There is a pair of III's right now on E-bay that comes with four sets of props. They are the newer style III's that had a crescent lower gearcase compared to the original straight leading edge case. I don't know how many years they produced the crescent III before going to the IIIA. There was a fuzzy time when some of the IV's were equipped with larger prop shafts. Ultimately, the IIIA and V were released, which got stronger gears, bigger shafts, the better trim pins, larger trim ram shafts, and a beefed up gimbal housing. The offical HP rating for these was 750. They've been run reliably at well over 1000. I've heard of people trying to pass off big-shaft IV's as V's. IIIA's and V's can run the same propellers as VI's, just with a different insert (1-3/4" shaft vs. 1-7/8"). Both use the same 26 spline pattern. That reminds me, if you do start off with a III or IV drive, you can buy 26 spline props, and get adapters from Arneson. That way, you not only increase your prop selection, but you can keep using the props if you do upgrade to a IIIA or V drive. That's what I did. Needless to say, props for these are very spendy ($2000-$4000 a piece) compared to Bravo props. |
tcelano- Thank you very much that was very informative and I really appreciate the help. One question though, if the boat is outfitted with a bravo is it really worth the extra money and parts to replace it with a III or IIA? I know these drives have to be run with a transmission so by the time you add up purchasing a drive, transom assembly, transmission,props, and various parts, and labor... would it almost be worth it to stick with a built bravo or even a BMAX if we could find a used one?
Originally Posted by gregga
(Post 3696048)
Agreed. I wanted to do mildly big power, not nearly what some people are running. And nothing says more than putting your money where your mouth is. I rigged SSM V's and would not even consider Bravo setups. In fact I made a commitment to myself to never own a Bravo boat. I am on my second SSM boat, and I've never even had a drive whimper, and definitely no failures after 9 years.
That's why there is a whole cottage industry for Bravos, and the SSM parts are all just reused from one guy to the next. |
What would be your thoughts on an Imco setup?? That way we don't have to mess around with changing the transom assembly and moving the engine forward ( which we don't believe we have the space for that as is) and getting into the whole customization aspect.
(Post 3697809)
RMPRam- Thank you for the help. I'm just stuck in between a rock and a hard spot because I want the boat to be reliable but on the other the owner does not want to have to remove the back seat so we are able to move the engine further forward because of the extra space needed for the transmission. We will have to go for one or the other lol Thank you for all the help guys.
Gregga, what kind of boat is it? How will it like the extra weight? Is there enough height on the transom to mount it and get the X you want?
You can always use an extension box to gain some room. |
What kind of power do you plan on running?
If you're not going over 850hp I would consider a BMax or IMCO for weight savings. If the boat is small, adding a #5 or #3A may take you backwards. We all want a #6 but at the end of the day I know people who have broken them also. :eekdrop: I think you just need to be "realistic" with your expectations in whatever you decide to upgrade too. |
RMP-or anyone who knows what is the correct order of fiber washers, washers, the curly spring looking thing and bolt. I am trying to bolt my transmission up to the transom assembly. I have a velvet drive transmision and number III drive. I also have a post on here asking this and a diagram was posted. In the diagram they only use one spring. I called and talked to a guy and he said each side should have 2 springs, what is the correct number and where do they go? Do they go just on top of the transmision mount or on top of and between transmision and transom assembly mount or just between them? Thanks for any help, because I am lost.
Anyone?
Originally Posted by bigboat28
(Post 3699474)
In the past, ive used clear silicone, to hold the fiber washer in place. Once the fiber washer is glued to the transom plate ear, the spring (actually a lockwasher), will sit in place, held by the bottom fiber washer. |
Thanks, any idea on how tight they should be torqued down?
I have a Cigarette 38 Hawk Edition 1988 with 2pcs 540 Hawk Edition engines and SSM III this boat is still orginal and it was only this build from factory with this setup and paint. Now I change my drive ratio to 1:62 (other drives) from 1:50 and run now 16 x26 Cleaver props but need to get higher in pitch is somebody with some same setup run and what pitch ?
CBB540 |
Generally a boat with a bravo in it is built around bravo spacing...and power. You want to run the power that will hurt any bravo derivitive,
you will also hurt the hull. I had a friend with about 900 hp in his Baja. It was VERY fast. Operative word here WAS. the hull split open. You want that kind of power, you want a hull designed for that kind of power. |
(Post 3699474)
| All times are GMT -5. The time now is 05:36 AM. |
