Bravo NOOB here...
New to the BRAVO scene. Have aleways had Alphas... Just need someone to verify that Bravos DO NOT have pumps in the outdrive like an Alpha. It is my understanding that they only have the sea pump that is belt driven. Is this correct?
Thanks! Also have a Bravo3 I picked up a while ago and believe that lower can be bolted right to the upper on a Bravo1... If someone could verify that as well I would appreciate it. Thanks everyone! Dustin |
Correct, the seawater pump/impeller for Bravo equipped boats is located on the lower starboard side of the motor. And yes, Bravo I and Bravo III uppers are the same.
May want to know what gear ratio you are putting together before you do it.
| All times are GMT -5. The time now is 01:58 PM. |
