-   -   Tailstock help (https://www.offshoreonly.com/forums/drives-lower-units/280101-tailstock-help.html)
bigo181979 07-06-2012 10:41 AM
Tailstock help
Ok I pulled my motor to replace my trans and when I did I found that my tailstock had spun a bearing at some point and to fix it the person bored it out more and stuck a band clamp around the bearing to act as a shim.... I kid you not!
So needless to say thats not going back in. The new transmission I got had a a different shifter set up then mine did and I have no idea how it mounts or works or what. The link is of what I orginally had with the shifter bracket cast ino the tailstock. The new one I got has a seperate bracket that appears to attach to the bolt that goes down through the tail stock and through the inner transom assembly, but again I have no clue I have never seen this set up before. Anyone have any ideas or can you help me out?
http://www.mercruiserparts.com/Show_...EMBLY+%28TR%29
Mbam 07-06-2012 02:06 PM
Post a photo of what you have
bigo181979 07-06-2012 03:44 PM
It will be monday before I can get out there and take a pic of it. It's inside my buddy's shop and he's gone until sunday night.
bigo181979 07-13-2012 10:48 AM
http://www.marineengine.com/parts/me...STERN+DRIVE%29
ok here is a link to what the tailstock that came with my new trans looks like. Anyone have a better picture as to how or where the shifter bracket mounts?
