-   -   Pitted Drive Clean Up (https://www.offshoreonly.com/forums/drives-lower-units/283288-pitted-drive-clean-up.html)
machloosy 08-22-2012 07:51 AM
Guys how are you cleaning up pitted drives? It's fresh water only and its a 1.32r alpha 1 behind a big block, not so easy to find. How can I fill in the pits and make this thing look factory nice again? Otherwise it is in pretty good shape! When I got it, the zink was so far gone, it was missing some of it's base :eekdrop:
Port Monster 08-22-2012 08:00 AM
I have the same issue - would be interested to see some answers. Coming from the outboard world I was just going to use the process they use for the installation/ feathering of nose cones - get the drive paint free and all oil and dirt removed and use marine epoxy to feather it smooth. http://www.hardin-marine.com/Instructions/620-11250.pdf
Biggus 08-22-2012 08:05 AM
I've had great results with Marine Tex ,
http://www.jamestowndistributors.com...word=marinetex
86Capri 08-22-2012 09:43 AM
Sand the paint off with 80 grit and get a little smooth. Then put a nice epoxy primer on it. Fallowed by a few coats of high build 2k primer. Then sand it down smooth with like 150. You might have to reapply a couple more coats of primer to get whats left. then make sure it is sanded with at least 400 and paint with a nice urethane single stage black.
machloosy 08-22-2012 10:29 AM
Sounds like the way to go is an epoxy followed by good filler primer, followed by a good single stage urethane. Anybody have before/after pictures??
86Capri 08-22-2012 12:00 PM
just after I wish you guys could have seen before.
[IMG]http://i1069.photobucket.com/albums/...2012160403.jpg[/IMG]
machloosy 08-22-2012 01:20 PM
Went searching a found this pic Capri. Definitely looks better than a Merc reman. Did you use a filler? Epocy or something else?
FIXX 08-22-2012 06:18 PM
fixx
you want to use a product from USC called ALL METAL..its a alunimum fiber mixed with vinalester resin..make sure its fresh,,when you open the can and its hard on top or looks dryed out take it back and get a fresh one..the stuff sands real nice too..follow up with ppg dp 90 epoxy primer to seal it up then paint it with imron..
dereknkathy 08-22-2012 06:23 PM
just remember. don't be too rough on the orig metal. it is getting thin in the base of the pits. you go grinding away or sand blasting it, and the oil may fall out. then it'll look like a brand new housing!!!
low_psi 08-22-2012 07:49 PM
I just redid my bravo drive. First I sanded down to bare aluminum. Used a wire brush to clean out the big pits then hit with a etching primer. Then used Evercoat Metal Glaze as a filler. It is easy to sand and applied with a spreader where I could and used my finger in other places. Sanded back down smooth then hit with high build primer, sanded again, then hit with duplicator engine enamel. Turned out great. I will try and post a few pics or the thread where I posted pics.
Rookie 08-22-2012 09:58 PM
5 Attachment(s)
Sand, fill, acid etching primer single stage urethane. I would not remove the base Merc paint if you do not need to.
machloosy 08-23-2012 07:33 AM
Rookie that looks good, are you saying just feather the paint everywhere and fill? What did you use as a filler, and what primer?
Rookie 08-23-2012 03:10 PM
Yes, I would feather in the paint. I only say not to remove the original paint is because I originally scuffed up the black factory paint and laid a coat of white DuPont ChromaOne on and the the paint never scuffed, chipped or flaked off of the original black paint. I have had some chips on the new paint that is on the aluminum. *Note* I am no paint expert but have painted my fair share of things. That original black paint on the drives is pretty tough stuff. This is just my experience. It cold be the self etching primer I used with the PPG paint.
Filler:
I first started off using Alvin Products Lab Metal (aluminum filler). This stuff stuck great and was as hard as a rock . But to finish sand with it was a pain in the ass. I spent a frustrating 20hrs on one drive trying finish sand the Lab Metal. I basically ended up die grinding it off the drive, I would not recommend it.
I am probably going to get flamed for this, but I finally ended up using Dynatron Dyna DeLite. I filled all the pits on the drive I had not touched and then skim coated the areas on the other. Sanded great, primed and then painted. The DeLite is similar to bondo but it is suppose to be water resistant compared to bondo. I had a piece of aluminum with DeLite stuck to it sitting in a bucket of water for 3 months with no ill effects.
machloosy 08-27-2012 06:08 PM
Sounds like the Dynatron is the way to go. Not looking to keep it forever. Rookie you prepped and sprayed w/ a hvlp gun?
Rookie 08-27-2012 10:41 PM
Note* I did sandblast the areas where the pits were to make sure all corrosion was removed.
Use a quality paint. DuPont ChromaOne or PPG single stage
http://www.harborfreight.com/air-too...gun-66222.html
machloosy 08-28-2012 07:23 AM
Sweet, winter project for sure. She has to get all pretty so I can sell it come tax time.
