-   -   trs alliment? (https://www.offshoreonly.com/forums/drives-lower-units/283859-trs-alliment.html)
bcfountain 08-30-2012 03:28 PM
trs alliment?
how critical is the alliment on a trs set up?i installed my motor/trans in my 10meter this weekend.when all was bolted up,and i stuck my alliment tool to check alliment,the plate on the alliment tool would not mate-up flusk with housing on the drive.bottom is good,but top has a gap about 1/8".if i raise up on the motor/trans,i can shorten the distance,but still not flush.i have offshore mounts,both front and rear.do i have to drill new holes or will the u-joints make up the diffrence?the starbord motor was almost perfect,maybe about .30".what gives?thanks all.
bowtie 09-01-2012 08:59 PM
Haven't done many TRS's lately but allways made sure the alignment was good. If not the drive could be hard to get on. And the U joints don't make up for bad alignment.
picklenjim 09-02-2012 02:43 AM
Keep in mind a TRS is a totally different animal when it comes to alignment than a Alpha or Bravo. The Alpha and Bravo have 2 completely seperate pieces, the gimble bearing and engine coupler which must be aligned with each other or the input shaft on the drive will not slide in through both. On the TRS there is no gimble bearing. You are sliding the input shaft of the drive directly into the transmission tail stock bearing and ingaging it with the trans output shaft. There fore if the alignment was off it would have nothing to do with installing the drive. Personally I think alignment is no where as critical on a TRS as it is on a Alpha or Bravo which must be perfect. I can tell you this, I have had my TRS boat 23 years and have had at least 5 different engines in it and have never once used an alignment tool on it. Not saying this is right but I have never had a issue with u-joints or anything related to this. Seems to me when you trim the drive you are doing the same thing as if you were raising the front of the engine up or down.
Unlimited jd 09-02-2012 07:02 AM
The alignment he is speaking of uses the aluminum plate and how square it sits with the bell housing. Not reading the grease mark from the splines. If that were the case you could bolt it in anywhere and it would be ok. I'm not sure how critical it is but would like to think you are pretty close.
MILD THUNDER 09-02-2012 07:40 AM
Personally I think alignment is no where as critical on a TRS as it is on a Alpha or Bravo which must be perfect. I can tell you this, I have had my TRS boat 23 years and have had at least 5 different engines in it and have never once used an alignment tool on it. Not saying this is right but I have never had a issue with u-joints or anything related to this. Seems to me when you trim the drive you are doing the same thing as if you were raising the front of the engine up or down.[/QUOTE]
I pretty agree.
picklenjim 09-02-2012 12:37 PM
Originally Posted by lil red (Post 3767455)
The alignment he is speaking of uses the aluminum plate and how square it sits with the bell housing. Not reading the grease mark from the splines. .
I understand he was talking about the TRS alignment tool. There is no way to go by reading the grease marks on the splines when aligning a TRS.
Unlimited jd 09-02-2012 12:45 PM
Ok I must have mis understood what you meant by the splines an bearing being off
502ss 09-02-2012 02:25 PM
As said by others I don't believe the alignment is critical mainly because no gimbal bearing. Mine was off also by roughly 1/8" on the top.
Rookie 09-02-2012 09:31 PM
I did have a problem when the tailstock bearing seized and wore down the input shaft on my drive. When I tried to put the shaft into the tailstock it would not line up. Hung down a few 0.001"s and would not slide into the splines. Sometimes it would take 3hrs and a miracle to get the shaft into the tail stock. I put 1.5 wraps of electrical tape around the shaft. Now it lines up and only take 5 mins to put a drive on.
502ss 09-02-2012 10:08 PM
That's a true "boating on a budget" fix right there! That's why we do what we do! :D
bcfountain 09-04-2012 09:12 AM
thanks guys for all you commints.my friend that is a marine guy was not sure.he thought that the alliment was not as critticalas a bravo..just wanted to be sure.this is the first trs i have worked with.alot of people said that when time to put the drive back into the motor that it was gonea b a pain.with the help of a cherry picker,i was able to get it done in less than a hour.i guess i got lucky.should i try to close the gap at the top of the housing by lifting up on the motor,and then tighten every thing ,or jus let er eat?thanks.
Rookie 09-04-2012 12:25 PM
Make sure the spring washer, and washers are stacked correctly. I also had an issue with that. Picklenjim was a great resource for me.
picklenjim 09-04-2012 12:36 PM
Those people that told you that have probably never worked on a TRS either. Alignement on a TRS has nothing to do with how hard it will be to get the drive on beings your plugging directly into the transmission. Alpha and Bravo MUST be perfectly aligned or you WILL have a problem getting the drive on.
Not clear on what your asking. Sounds like you already have the drive on. Are you saying there is a gap at the top between the drive and housing now? Hope not.
bcfountain 09-04-2012 02:21 PM
no,drive not on that side,port.starboard ok.what i ment was when we droped the motor/trans in,i stuck the alliment tool in jus to see what it looked like.the plate at the top has a gap about 1/8 inch.bottom is flush.the starboard side was like that also,but not as much gap at top.only about ,060 if that.i havent tried to put the drive back on the port side,the one in question.if i lift up on the front of the motor,i can close the gap somewhat.should i do this or just let it be.this is a diffrent block,but same kind.what do you think.thanks for all your help.brad
picklenjim 09-04-2012 03:36 PM
If you are using the same mounts and setting it all up the same way as the previous engine was then I would just go with it. If you can lift the front some to help then go for it. I don't know if it will stay there though if your talking about just raising it with in the hole on the OS mounts.
