S/N look up
Can anyone help me look up a serial number 0W483547... Thanks.
FYI its a transom assy |
Originally Posted by 2fast9tech2
(Post 3808226)
FYI its a transom assy http://www.perfprotech.com/mercruise...10/60?model=90 |
Originally Posted by picklenjim
(Post 3808300)
Don't understand just what your looking for. A diagram of it?
Thats a standard transom with smartcraft senders
TRN: 0W483547 6315001TS MERCRUISER BRAVO SMARTCRAFT, late 2005 |
Originally Posted by Mbam
(Post 3808352)
(Post 3808380)
Thanks for the info but looking up 6315001TS it says its a magnum transom assembly?
Boatswainslocker.com appears to have model number 6315001TS listed incorrect to me.;) Try running your serial numbers through this link, https://webapps.brunswick.com/litera...atureSearch.do |
Originally Posted by lakematdude
(Post 3808441)
If you look it up on the brunswick website, Model number 6315001TS comes up as an MERCRUISER SMARTCRAFT TRANSOM W/ENGINE BRAVO SMARTCRAFT
Boatswainslocker.com appears to have model number 6315001TS listed incorrect to me.;) Try running your serial numbers through this link, https://webapps.brunswick.com/litera...atureSearch.do http://www2.best-boats24.net/pl/kupi...&oa_langcode=1 http://www.euronautica24.com/Advert/...aProizvod=1877 |
6315002NZ - TRANSOM ASSEMBLY, SmartCraft (496 and Digital Throttle/Shift)
6311002NZ - TRANSOM ASSEMBLY, Magnum (All - Except 496 and Digital Throttle/Shift) |
(Post 3808448)
arent all smartcraft magnum? thought the smartcraft was usually tied to a 496. if you google 6315001TS several boats with 496 are listed with this part number.
http://www2.best-boats24.net/pl/kupi...&oa_langcode=1 http://www.euronautica24.com/Advert/...aProizvod=1877 In the link below you will notice your serial number utilizes the bigger U-bolt & Nut like the mag T/A. item numbers 24 & 25, http://www.mercruiserparts.com/Show_...Steering+Lever Also take notice of the ( ) between the (Magnum Transom) & (SmartCraft) SN# 0W465665 & Up indicating two transom designs. Another thing you can do in the brunswick website link is open Product Line, go to MERCRUISER 1998+, scroll down to "BRAVO", Click on the first BRAVO you see just under blackhawk, there you'll find a list of T/A model numbers. You're model number & all the model numbers you posted can be found in there as well along with basic information about them. |
(Post 3808484)
Are you thinking a 496 "MAG engine" HO 425 HP B3X should/would automatically come with a mag transom assembly? If so, that would not be the case.
| All times are GMT -5. The time now is 08:31 AM. |
