-   -   transom assembly (https://www.offshoreonly.com/forums/drives-lower-units/287961-transom-assembly.html)
Wellcraft1 11-19-2012 04:23 PM
transom assembly
My 26 nova has severe slop in steering. Can assemblies b repaired or do they hafta b replaced?
Amarket Owner 12-13-2012 04:39 PM
Slop in steering
If the slack is on the square side of the shaft that passes thru the ring, therer are possible cure.
1) There is a company, Mike Lasky sells a oversize shaft.
2) A piece of shim s.s. v shaped on two sides on the shaft then tightened until the slack goes away.
If the slack is on the top, just change the shaft and tiller.
good luck.
