Transom plate hose problem
If you have a bravo transom plate with the front tip of the water and anchor plug crushed blocking the hose, please post here a jpg of the inner surface with the plastic adapter removed showing the crushed hose.
I need a picture for the instructions for the repair kit we sell. Thanks in advance. Buddy |
This is not mine, just something i ran across a few days ago, is this a photo of what your looking for?
http://clubsearay.com/showthread.php...429#post634429 |
The picture is a perfect vision of the problem. I do not belong to that forem so I cannot help but if you can tell him in appreciation of his picture I would supply with our repair kit at 50% discount.
I noticed the threaded areas and the gasket gurface look usable, but I have been told some get so bad that the screws hardly hold and require a new transom plate. We have a new add on kit available son to help the worse cases. Thank you Buddy. http://amarket.com/f654.htmHELP SHEET repair kit http://amarket.com/im654.htm |
| All times are GMT -5. The time now is 09:08 PM. |
