Gear Oil Weight Question....
I am on my 3rd set of gears in the LH unit on my twin O/B Sonic.
I am building my own "Lightning" (OMC/BRP's performance housing) LH unit as the factory never produced a LH version. I am using used RH housings that had previously lost a set of gears as thats all I'm finding available. I just lost the 3rd set and am on my second used housing. I suspect the housings being tweaked when eating their orig set of gears. Before swallowing the cost of a new OEM housing I'm experimenting w/some changes on this build. I'm looking at gear lube. I switched to synthetic 75/85 yrs ago and never lost a unit until these lefties and that includes many high HP, 7500 RPM and up motors. I've been using the cheapest synthetics at the auto parts stores which is normally Valvoline. Now I'm looking at two things. #1. Upping viscosity from 75/85 - 85/140. #2. Trying some high zoot fluids like you guys run in your high dollar gear cases. I did a search and read everything on here and it seems you guys like the custom (Neo) blend from the Bravo shop which only comes in 75/85. I'm not concerned w/the additional drag of the heavier oil, I only want these damn things to survive. Wouldn't I be wise to go to the 85/140 which Neo offers?? Be interested in any input from you wizards. Also thinking of Cryoing the LH gears. Thanks Guys! Gary |
I've been using Amsoil 75w110 severe gear in my XR,and all my previous bravos....IMO,75w85 is too thin for a drive pushing some serious power....maybe others will chime in...
I second the AMSOIL 75w-110.
I run amsoil 75 110 but would run the bravo shop blend before the stright neo blend. I dont know why a heavier weight would be better besides the simple fact that the number is larger sounds better.
Originally Posted by offshorexcursion
(Post 3853208)
That was...
Originally Posted by pqjack
(Post 3853562)
high horsepower engines will make your drive run hotter...heavier weight wont get as thin,help preventing metal/metal contact....same as running 5w30 in your hi-perf engine
Thicker oil was the way to go back in the day but actually it just more friction/heat, its all in the add pack in the oil that protects the gears and bearings.
Here is something for you to ponder. Why did nascar start running 0 and 5 weight oils in there engines if the technology wasn't there to support it? |
-100
Thats no longer true. I`m gonna run mantec 80w-90 Mild Thunder also found this place which is local http://www.leahywolf.com/const.html Their gearmaster oil is $75 for a 5 gallon pail.. can`t beat that. |
Not trying to be a wise guy here, but there are other issues causing the failures. No oil is going to make something wrong all of a sudden right. With that said I'm not a chemist and don't know the why's. But, I do know first of all that gear lube viscosity isn't measured the same as motor oil. A 75 viscosity is not nearly as heavy as you think. I believe it is more like a straight 30 maybe 40 weight motor oil. Second, and more to the point is as mentioned above the add packs. What is important is the oil's shear strength, it's ability to stick to the gears. A good synthetic 75/90 or 75 whatever according to who you use is fine. I do not believe the heavier oil is going to make a difference in its ability to bond on the gear.
Originally Posted by benjen
(Post 3853797)
In class 8 semi trucks, most run 50WT engine oil, or 80W90 in the transmissions, and 80w90 in the rear diff's. Parts go a million miles plus sometimes. Cant say theres no load on those gears hauling 80k + lbs up mountains. |
i was suprised when it was time to change the gear lube in my ford f250 4wd,it called for 85w140 in the rear axle,and the gears are large for a pick up truck.
Originally Posted by mike tkach
(Post 3853853)
My trans temp in my semi on a hot day fully loaded runs about 160-180*. I think if the gearcase temps start getting in the 220+ range the 140W oil works better. I wonder if I should add a temp gauge on my dually rear end and see how hot it gets towing the boat. That would be cool, and a good way to determine what oil to run in it. Be nice to add one for the drives on the boat too! Of course synthetics play a role too! |
Originally Posted by MILD THUNDER
(Post 3853860)
I think its a temp thing. If the operating temp exceeds a certain number, the thicker oil comes into play. I don't think its as much as a strength thing as it is temps. Im sure ford had a valid reason to change the spec on that diff, as it used to be 80w90 I believe in the Dana 80, if that's what you have in yours?
My trans temp in my semi on a hot day fully loaded runs about 160-180*. I think if the gearcase temps start getting in the 220+ range the 140W oil works better. I wonder if I should add a temp gauge on my dually rear end and see how hot it gets towing the boat. That would be cool, and a good way to determine what oil to run in it. Be nice to add one for the drives on the boat too! Of course synthetics play a role too! And if zero or five weights are so good in a nascar engine,who's going to be the first one to use it in his boat engine?? not being sarcastic...just curious,as im always willing to learn something |
Thicker oil actually increases temperature.
Bravo Shop 75-90w oil will protect up to 400 deg. Talk to the folks that have used it and have seen unbelievable results not only in gear life but bearing life as well, they still look like new after being used for a season. We have been testing a 50-60w also in outdrives with the same results as our 75w-90. We have temp senders for outdrives and I have adapter them to my dually just for the same reason Mild Thunder stated above and I now run Bravo Shop 50-60w oil in rear axle and in the manual transmission of my 04 Chevy. |
No doubt.
(Post 3853797)
Thanks for all the help guys. Keep it coming. |
Now, this is a cool debate:party-smiley-004: typically oil with wide viscosity ranges are used where tolerances change alot. NASCAR, and other racing organizations typically use low weight oil because it flows easier and creates less resistance to pump (free HP). Most "real" race engines are not loaded fully until brought up to operating temp to ensure the clearances are at a predictable size. A good oil, will hold the film size (based on the viscosity) at the temps they are designed for.
In my opinion, drive tolerances are wide enough to support the 140W (in multi-viscosity design only) number. But not enough to make up for being compromised due to excessive load. |
Do a Google search on REM polishing. I know some people in the race car world are having very positive results, with transmission and rearend gears.
fixx
Originally Posted by ICDEDPPL
(Post 3853789)
-100
| All times are GMT -5. The time now is 08:44 PM. |
