-   -   Which prop? (https://www.offshoreonly.com/forums/drives-lower-units/290725-prop.html)
Pete Loomis 01-27-2013 06:34 PM
Which prop?
Hi guys. I have an 88 checkmate convincor 25ft. I am in the process of putting in a 435hp 502 efi. Wondering what prop would be good. I had a 330hp 454 previously with a 23p three blade. Obviously want a good balance of speed and getting out of the hole. Any suggestions would be great. 3 or 4 blade??
picklenjim 01-27-2013 06:46 PM
24P Bravo 1 which is a 4 blade would probably work good all around. I would put that 23 on and see how it runs first and see how many rpm it will spin at WOT. That will give you a starting point. What 23 is it? How many RPM would the 330 turn at WOT with it.
abones 01-27-2013 07:07 PM
Pete can we assume a 1:50 ratio? I had a 88 convincer myself, 1:33 gears, 26 pitch three blade outboard cleaver, 4" shorty, 454/650HP ran 101 with 9% slip stable as could be. You hull will handle the speed, with the right set up.
Do you have merc K planes?
abones 01-27-2013 07:11 PM
also be carefull on the 4 blade might give you to much stern lift with a deep X dim, stern lift is not good for that hull it will be unsafe!
Pete Loomis 01-27-2013 07:17 PM
Thank you for quick replies! The 23p was a mercury mirage. Yes I do have short trim tabs. I believe that I would turn about 4600 with the 330 in it. I see some good deals on used 25p 3 blade mirage props. Not sure if that would be too much. Yes I have bravo drive with 1.5:1 I'm 99% sure. And here's another thing, don't want to ask a stupid question but obviously my motor is a lh engine and my prop that I looked up says rh turn. So that would make sense I need a rh prop? Thanks again for input
abones 01-27-2013 07:26 PM
yes Rh prop 99% of the motors turn rh looking fom thr front so when looking at the crank it rotates correctly in a counter clock direction. I would start with the 25 three blade, record all the stats, fuel level, #passangers, water conditions, RPM, and speed. keep a book for reference, so you can make decisions based on facts. JMO.
Pete Loomis 01-27-2013 07:55 PM
Ok great advice. The cleaver prop you used was solid hub? Good or bad idea on my bravo drive? Anything I would need to change on the drive? Stick with 14.5 diameter or so? Sorry for so many questions. I appreciate the help. Pete
abones 01-27-2013 08:04 PM
The cleaver was a solid hub, but that will not work at all for you unless the X is raised a lot, they are surfacing props, absolutly go with 14.5 dia props remember the faster you can spin the prop the better. your boat will suffer with a bigger dia wheel. how many RPM max do you want to turn?
Pete Loomis 01-27-2013 08:28 PM
I know the engine is assemblied well, but is mostly stock. I don't want to beat the hell out of it. I was thinking between 4800-5000 wot?? What do you think. Want it to stay reliable for a long time.
abones 01-27-2013 08:39 PM
5000 sounds safe, if you can spin the 25 to 5000 with 12% slip you can see 70 MPH, once you get your test data, contact merc, bblades, cutting edge, etc, for fine tunning. keep us posted!!
